possible with only 4 connections on the back of the display?
the system fans that can be plugged in, can the rpm be adjusted for each
individually? Lastly, will this be the display used in the MX4 kit?
Cheers in advance...
I've been getting this question a lot so I figured I would finally get around to answering it:Please can you confirm that the LK204-24-USB-WB 4x20 line display is powered by USB and has the ability to monitor temperatures? If this is so, how many temperatures can it monitor? I have read through a lot of your forum posts, and one says you can monitor up to 32 temps, but how is this possible with only 4 connections on the back of the display?
YesAlso, with the system fans that can be plugged in, can the rpm be adjusted for each
individually?
Yes the MX4 series kit will be using the LK204-24-USB series.Lastly, will this be the display used in the MX4 kit?
