Two VFD's running on one PC?
Glenn_L
Post by Glenn_L »
I want to run a VK204-25 and a VK202-25 on the same machine, would this be possible. Could I run two instances of LCDC or one instance of LCDC with one instance of Girder. I am coming out with a new HDD storage case and want to monitor drive status on that case. Was planning on using com 1 and 2.
-Glenn
AtechFabrication.com
Re: Two VFD's running on one PC?
Glenn_L wrote:I want to run a VK204-25 and a VK202-25 on the same machine, would this be possible. Could I run two instances of LCDC or one instance of LCDC with one instance of Girder. I am coming out with a new HDD storage case and want to monitor drive status on that case. Was planning on using com 1 and 2.
Yes you can... each unit will have to have it's own software running, like you said, two copies of LCDC and one LCDC and one Girder.
