I must be slow...but I can't get Fraps working...PLEASE HELP
Dstima
Post by Dstima »
As the title says...I have no luck getting fraps to be "active" according to LCDC.
I have tried 1.9c, 1.9d and 2.0 demo...all to no avail. No matter what I try I get the error: "Framerate data is NOT active"
Any help would be great!!
Thx,
Dan
CMW
Post by CMW »
The plugin was written for Fraps 1.9c, so use that to get started, the fraps plugin is odd because it will not see fraps as active until it is running during some sort of video mode, so start fraps, select a fraps screen in lcdc and start the display then start a game or a video and you should find it works :w00t:
Hope this helps!
Mat-Moo
Post by Mat-Moo »
Fraps does work with 1.9c and onwards. Remembers though that fraps only reports with DX is being used (e.g. in game). So if you see the Fraps counter on the screen you should also see it enabled and the data avaible to LCDC.
## # Mat # ##
http://www.lcdc.cc
Matthew@DPS.uk.com
DPS Ltd. (Not MO!)
