GLK12232-25wbl just says "graphics in any directions&qu
bbcac
Post by bbcac »
Can someone tell me what is wrong. I've connected my LCD but it just says "graphics in any directions". I suppose that's the defualt picture. I've done the reset procedure. I've tried MOGD, LCDC, and the tuner app but they all fail to change the screen. I've reset my thing 50 times but still no luck. If I'm lucking the screen will flicker when I sent a command, but thats it.
sounds like you got Rx and Tx reversed on your cable.
bbcac
great its working
Post by bbcac »
Thanks a lot. Funny thing really. I had the connectors on the 4dr end crossed by accident. So before i ever tried the display i crossed them back. But it turns out that I had the wires connected backwards too so it would have worked fine. But when I tested it with a multimeter it turned out that it was wrong. I crossed them back again, and it works fine now. THe display doens't display quite right but that is something that I can see is a common problem, I am sure that I will be able to correct that. Thanks for your prompt help
Luke
