LCDC
Delta
Post by Delta »
cheers :smile:
ive just tried adding it a screen, but its constnatly refreshing the image - how do i stop that?
Mat-Moo
Post by Mat-Moo »
Bit snookered on that at the moment... Better way to do it is draw little custom characters as part of your font file :smile:... There will be some further changes later on for better support of GFX displays...
Delta
Post by Delta »
:smile:
it was a fullscreen graphic i was wanting it to display, planning using it as a templete and then placing text kinda ontop of it.
what font do u recomend with LCDC btw - (not an inverted tho :/)
Cheese
Bit-Tech.net
Bit-Tech.net
Post by Cheese »
On 2002-03-21 12:45, Delta wrote:
cheers :smile:
If you do as I tol dyou it won't refresh.
As for a non inverted graphic font, small filled is good, or http://users.ox.ac.uk/~some0814/CheeseFont2.zip should make the bargraphs work. DOn't use the definition file in cheesefont2 now though.
r.
Cheese
Bit-Tech.net
Bit-Tech.net
Post by Cheese »
This was done by using a template in the way you suggest... bit of cursoring need to update the 'sys info' box when it changes screen, 5 different fonts so I have to change the font and metric on the fly, and some more cursoring to put the temps where you see them. It's a little messy to do but it works...
r.
ultraspider
Post by ultraspider »
the Cpu stuff (load % text and load bargraph ) aren't working and the gpo toggle (on/off) isn't working too. is it a bug in the program or in my computer ???
i'm trying the gpo toggle with a keypad press, (the keypad is working i have tested it with another event).
<font size=-1>[ This Message was edited by: ultraspider on 2002-03-21 14:38 ]</font>
On 2002-03-21 14:35, ultraspider wrote:
the Cpu stuff (load % text and load bargraph ) aren't working..
DOuble check you have Enable CPU usage checked in MBM5... LCDC reads that info from there now.
ultraspider
ok thx, don't you know about the gpo toggle stuff ?
Mat-Moo
Post by Mat-Moo »
Cough - Fixed!
ultraspider
On 2002-03-21 15:18, mat-d-rat wrote:
Cough - Fixed!
it will be fixed in the next version or can I allready download the fixed program ?
the power shutdown command doesn't working either. :-( (under WinXP pro)
<font size=-1>[ This Message was edited by: ultraspider on 2002-03-21 16:13 ]</font>
Mat-Moo
Post by Mat-Moo »
Sorry it will be in the next version... erm Shutdown don't work?? I'll look into it...
controller2k2
Post by controller2k2 »
I just wanted to add that this is a fantastic program and I will be paying to register when that is online!
I just received my display kit today, and went through all the available programs. I liked Smartie, but it seemed to have too many quirks like shooting the CPU usage up, etc.
LCDC is fantastic! It is -very- customizable, has a -nice- interface, and runs extremely well in it's latest version! I am very, very impressed!
Only one suggestion which may not be possible using the MBM plugin:
Is there any way to display the temperatures in F as opposed to C for us Americans? :smile: I'm thinking that MBM probably passes the info in C and this would have to be coded as an option in the plugin, but it can't be too hard.
Again, great work!!
From Paul
Boston, MA, USA
Mat-Moo
Post by Mat-Moo »
Ah drat, I have to admit I thought the MBM info would come over in whatever format was chosen in mbm... Let me try and sort that...
Delta
Post by Delta »
would it be possible have LCDC display signal strength of digital radio along with what station its tuned into? (http://www.dabbar.co.uk/dabbar.htm - might help if ur not sure what i mean)
would it be possible to add a character that would only show up if you've got new mail. atm i have a seperate screen which doesnt display if theres no new mail, but i'd like to add a character to every screen so i can glance and know if i've got mail or not - you like that little envelope that appears in the system tray when using outlook experss
CyPher
Post by CyPher »
ive yet to try the function, but can you control how fast the gpo turns on and off, cause if you can, it would be cool to include a function to vary the speed of gpo on/off cycling...so you could control the speed of a fan.....set it up with the bar graph finction...and use it with a few switches....and instant variable digital fan controller
just a though...if posible i think this would push the software over the top for us lk204 25 pc users....
