ok, I changed my mind and decided to go with rocker switches instead of pushbutton switches. Considering I'm controling things like lights on/off I figured they would be more suited, not to mention look better. Now here's where I ran into some trouble... do I want momentary on, or momentary off? Chances are the light will be on more than off if that helps any. So anyway, I can purchase a switch with either the configuration:
on - (off) OR
(on) - off
Once I have the right switch, all I need to do is solder it to a cd/audio cable which plugs into the keypad header on the LCD, correct? Or am I missing something here?
Cool, thanks. I found a cable with a 2 pin connector on an old fan and used that to connect to the LCD's keypad header, so I suppose now all I need to do is solder it to the switch and it's good to go!
