LCD Smartie 5.0 release
ScoobyDo[UK]
Post by ScoobyDo[UK] »
I also get the following error message
" is not a valid integer value
The Program runs for about 3 seconds, then the above error message appears and keeps appearing in windows galore!!..??
Smartie4 works fine. Im running XP.
<font size=-1>[ This Message was edited by: ScoobyDo[UK] on 2002-01-24 10:49 ]</font>
relix
Uber Slave
Uber Slave
Post by relix »
okay, for the nondelphi programmers: '' is not a valid integer, appears when the program tries to convert a string into an integer.When the string (in this case, probably a text-box) contains nothing ('') or not a number ('blablabla') this error is raised. Try searching a text box, or anything of which you can change the value, that is empty, and change the value to a valid number. This way the error will not be raised again (normally).
Cheese
Bit-Tech.net
Bit-Tech.net
Post by Cheese »
Download seems to be working fine for me, but just mirrored it here - http://users.ox.ac.uk/~some0814/smartie5%5b1%5d.zip too :smile:
r.
BasieP
LCD Smartie
LCD Smartie
Post by BasieP »
okay okay:
it was all my fault, i made a stuppid fault. (wrong config file)
please download again
(the link above this post, is invallid, or old and valid)
and about that 'Unable to locate the "prossor" performace object' thing, that's an very big error in XP
but ofcouse M$ doesn't care :wink:
just turn CPU usage off
<font size=-1>[ This Message was edited by: BasieP on 2002-01-24 11:12 ]</font>
ScoobyDo[UK]
Just downloaded the program again.
It gets further this time, switches to the 2nd screen (Youve got email).
but then it crashes again with the same
" is not a valid interger value.
twain4me
Post by twain4me »
Jup same probleme here...... ussing win 98se
(btw thanks for the link)
specialk
Post by specialk »
http://www.geocities.com/special_4k4/im ... martie.jpg (drag and drop)
I have the same problem as everyone else...
-special [k]
_________________
"An unsupervised teenager with a modem is as dangerous as an unsupervised teenager with a gun." -Arizona State Attorney Gail Thackeray
Chemical name: Cyclohexanone, 2-(2-chlorophenyl1)-(methylamino)-cyclohexanone hydrochloride, C13H16ClNO
<font size=-1>[ This Message was edited by: specialk on 2002-01-24 11:27 ]</font>
ScoobyDo[UK]
Got it working :smile:
It didnt like SCREEN6 in setup,where it displays harddisk info etc
Disabled this screen and it worked fine :smile:
ScoobyDo[UK]
The main cause was probually because it was trying to display the info for Drive E which is my CDROM and couldnt.
Ive now enabled screen6, and successfully display info for Drives C and D
If you keep on getting the " interger error, the best thing to do is to go into setup, and disable all the screens, enabling one at a time, until you narrow down the error.
if I click on the Matrix Orbital advanced LCD options I get:
'-' is not a valid integer value.
BasieP
LCD Smartie
LCD Smartie
Post by BasieP »
AAGH!!
I dont have ANY but ANY troubles with it..
can someone please tell me it IS working?
perhaps you don't have MBM 5.1?
winamp 3 perhaps? (only works with 2)
windows CE???
Windows 2000 Pro
WinAmp 2.77
MBM 5.1.0.2
if I turn all the screens of it doesn't give errors :smile:
Well, the winamp title will scroll just fine, i'm turning on the screens one by one... seeing where the error happens...
_________________
<font size=-1>[ This Message was edited by: Henry on 2002-01-24 11:40 ]</font>
<font size=-1>[ This Message was edited by: Henry on 2002-01-24 11:45 ]</font>
specialk
Post by specialk »
Windows XP
Motherboard Monitor 5.1.0.2
Winamp 2.78c
(Also, I use LCDriver because my screen is a parallel hooked up via a wirz serial backpack, so that *may* cause an issue or two)
-special [k]
_________________
<font size=-1>[ This Message was edited by: specialk on 2002-01-24 11:43 ]</font>
if you get:
remove line 2 from screen 3
working @ $CPUUsage%%$Fill(20)$CPUUsageBar(20)
I think we have it fixed :grin:
