Installing the Internal USB Cable
Did you find this guide useful?
5 Very much so!
0
No votes
4 Not too bad
1
33%
3 So so
2
67%
2 Not very much
0
No votes
1 Not at all
0
No votes
Total votes: 3
jontce
Post by jontce »
Like walkinginfog, I am having trouble with my display, mine is a MX530. I've owned an MX2 series before, and i've had the same problem with both! Like walkinginfog, i also have an ASUS A8N-SLi Deluxe motherboard. My display is plugged in and the USB cable is fed out the back of the case and plugged into a free USB slot. I've plugged a mouse into that USB slot to ensure the USB is working correctly.
The display is not recognised by windows and it has no power. This also happened with my MX2 display, and to fix that I used a different USB cable other than the supplied one, and that did the trick.
I have the same ports listed as walkinginfog also, so a fix for him/her will probably also work for me. What should I do?
Hi jontce,
The MX530 requires power from an unmodified floppy power cable and the usb cable. Walkinginfrog over looked the unmodified floppy power cable, so you may be doing the same thing.
Try this, and let me know if it works.
jontce
Post by jontce »
Tom wrote:Hi jontce,
thank you Tom. That has sorted the problem.
Excellent work, fast response, i'm delighted with my purchase.
jon
Jon,
Glad you got it working.
Recoil
Advice on a mx222
Post by Recoil »
Hi there,
I just recently given a mx222 for my new case :)
I've got a Asus AV8 Deluxe Motherboard.
Ive done very little readup about them..
My question is? I know the 4 internal pins for the USB connection need to be added. Should I need extra power? I see the 4pin connector. Again if this has been mentioned in the past, or posted somewhere where i should of read:P
Thanks in advance
Ste
Hi Ste,
The MX222 does not require extra power to turn it on. The external power is only to power up the high power gpos. The only display that needs the external power are the MX5 or VK204-24-USB displays.
Recoil
Post by Recoil »
Yeah i got it working, but now ive just found out that my friend has registered LCDC and i need to get his pass off him (i hope)
Did you get a cd key for LCDC? It sould have been on the ecd that came with your display.
Recoil
Post by Recoil »
I have got a key with the cd i got, but i cannot enter it.
I got to www.lcdc.cc/bundle and it says the keys been activated :(
Recoil
Post by Recoil »
correction..
Was www.lcdc.cc/bundled !
Did you purchase this display used?
Recoil
Post by Recoil »
A friend purchased 2 mx 222's, but i guess he has activated the wrong disk to the box. And I wont hear from him for sometime as he's travelling around europe
Maybe you can ghold of him by email to get the other key. LCDC is a 30 day trial until you register it.
Recoil
Post by Recoil »
doubt it, but i can try, hes travelling all over europe.
might use that LCD Smartie.
You can try emailing Matt at LCDC to see what he can do at Matthew@dps.uk.com
