Moderators: Henry , Mods
BLZBUBB
Posts: 8 Joined: Wed Jul 30, 2003 8:30 am
Post
by BLZBUBB » Fri Sep 05, 2003 5:51 am
As the title says really.
How do i do it? i have some ultra bright LEDs lying about and i want then to indicate various info from my LCD.
What is the maximum independent LEDs I can connect?
And more importantly how do I connect them? (Big writing version with pictures please
my electronics aint great
Thanks for any help
MX222
WaterCooled XP2100
Posts: 1105 Joined: Mon Mar 04, 2002 4:00 pm
Post
by Miles » Fri Sep 05, 2003 10:53 am
The MX Series has 6 GPO's...You have the option to make all GPO's low powered, however you must be advised only three have current limiting resistors (5V @ 20mA). From default settings you have 3 GPO's that you can use independently and three that you would need to add a current limiting resistor to. If you have any further questions, feel free to post.
BLZBUBB
Post
by BLZBUBB » Fri Sep 05, 2003 11:17 am
Ok I am using the high power GPOs at the mo so only need to use the low power ones.
Could anyone show me on a diagram where the low power GPOs are located. I see the keypad input pins and the fan headers and white plugs which i presume are for temp probes?
the only other pins are a set of five pairs of pins next to the power input.
Are these the low power outputs
thanks for the help
MX222
WaterCooled XP2100
Post
by Miles » Fri Sep 05, 2003 11:27 am
Please see the following link for a pinout diagram...
http://www.lcdforums.com/forums/viewtopic.php?t=1421
On the PCB it will be labelled "4" to the left of the connector...The 3 low powered GPO's are 4, 5 and 6...
BLZBUBB
Post
by BLZBUBB » Fri Sep 05, 2003 11:47 am
Ah i got it now
but that still leaves four pins in that group.
So what is this final pair of pins for
again thanks for the help
MX222
WaterCooled XP2100
Post
by Miles » Fri Sep 05, 2003 11:54 am
Pin 7 is a "no connect" and pin 8 is 5 Volt power output...
BLZBUBB
Post
by BLZBUBB » Fri Sep 05, 2003 11:58 am
Ah cool.
So could i just use pin 8 to power a single LED that will be on the whole time?
MX222
WaterCooled XP2100
Post
by Miles » Fri Sep 05, 2003 12:06 pm
No...
Pin 8 does not have a current limiting resistor and will damage you LED in a hurry!!
BLZBUBB
Post
by BLZBUBB » Fri Sep 05, 2003 12:08 pm
lol ok.
Thanks for all the help
MX222
WaterCooled XP2100
Post
by Miles » Fri Sep 05, 2003 12:11 pm
No problem...if you need anything else, don't hesitate to post!!
