lk202 USB block/blinking cursor problems (VB)
I executed the instructions provided and the utility returned success.
This code now results in the output indicated below the snippet
MSComm1.Output = Chr(254) & Chr(72)
MSComm1.Output = "AAAAAAA"
MSComm1.Output = Chr$(254) & Chr$(71) & Chr$(1) & Chr$(2)
MSComm1.Output = "bbb"
MSComm1.Output = Chr$(254) & Chr$(74)
MSComm1.Output = "cc"
Line 1:ccAAAAA
Line 2:bbb
No underline
254 + 83 = no block either.
Next?
Line 1:ccAAAAA
Line 2:bbb
No underline
Next?
Serial number should be FFFF unless you've programmed it. uProject doesn't detect the display type properly with these ones. The one I'm worried about is the revison of 0xFF, which indicates that your memory is not initalized. Does your display have a startup screen still?
James McTavish, P.Eng
Director of Engineering
Please contact me at myero@matrixorbital.com and we'll resolve the issue.
I have the same problem !
I have exactly the same problems as described by dconnell. I can't get block or underline cursors to work.
Don't think I can tell what my PCB revision is, as I have an MX2, and I guess I can't see the etching. There's a handwritten serial of '03M08-827'. My firmware revision comes back as 0x20. I don't want to try the firmware upgrade as I'm not sure what the PCB revision is.
I have a second MX2, but haven't tried that one yet.
Can I have some support, please ?
Sounds like you have the memory file that has the bug. Head over to http://www.lcdforums.com/forums/viewtop ... highlight= and follow the instructions at the bottom of the page. Let us know how it turns out.
URLs are not working
Gary Roussak
Update: The file link has been updated in that post. The new link is
http://www.lcdforums.com/download/MemUploader.zip
Hope this helps.
Hope this helps.
Successful outcome
You may already know, but just wanted to point out that, when altering Contrast and Brightness with uProject, spurious characters are sent to the display (from the top half of the ASCII table).
