Keypad not working?
Keypad not working?
I When I get to #4 of the description for the Winamp3 pugin ,4 (Put the mouse cursor into the Parameter for that event (keypad) and press which ever key you want to perform an action on the keypad. A single letter (Like H) should appear in the box) It doesn't work. No matter what I press no letter appears in the parameter box. I have been trying to configure my Winamp3, and MB5 and I am getting increasingly frustrated. Any help appreciated.
Thanks for the resonse Calvin166. What do you mean by button that looks like an eye? There are no buttons on my faceplate other than the four arrows, and F1, F2, and Enter.calvin166 wrote:there should be a button that looks like an eye. make sure that is pressed. its at the top.
I think I may remove LCDC and re-install everything. I have tried to follow the how to's on this website, and the LCDC website with no luck. I don't know.
In order for LCDC to put the correct "Parameter" / keypad value in the "Preview" option must be turned on. In the screen building there is a bad picture of an eye looking left (been replaced in the latest beta) which must be on for this to work. So just select "Sys->on keypad press" as the event, then click into the paramter section and hit one of the keypad keys and you should see a letter pop in there. The other option is to go into the "Configure/Test" and select the test option, then whenever you press a keypad key, you will see in the test area what value it returns, which you can then type manually in to use.
## # Mat # ##
http://www.lcdc.cc
Matthew@DPS.uk.com
DPS Ltd. (Not MO!)
http://www.lcdc.cc
Matthew@DPS.uk.com
DPS Ltd. (Not MO!)
