Using a GLK24064-25-VPT-E .
What is the maximum rate it can accept keypresses on the 25 key keypad before it starts to lose keypress data?
Is the keypad debounced? If so, what is the bounce delay?
(How) Does it handle rollover (two keys pressed at the same time)?
Does it buffer keypresses in any way? I know my serial port buffers incoming data, but does the board do any buffering?
-Chuck-
GLK24064-25-VPT-E What is the Max keypress rate?
More info
Humm, perhaps I should have posted this question on the Software Board?
Here is the code I am trying to use:
It logs this data:
2003-04-05 21:20:42.223 BlueCabbie[1955] 1, 75, 4b, K
2003-04-05 21:20:42.513 BlueCabbie[1955] 1, 95, 5f, _
2003-04-05 21:20:42.817 BlueCabbie[1955] 1, 75, 4b, K
2003-04-05 21:20:43.133 BlueCabbie[1955] 1, 75, 4b, K
2003-04-05 21:20:43.426 BlueCabbie[1955] 1, 75, 4b, K
2003-04-05 21:20:43.723 BlueCabbie[1955] 1, 95, 5f, _
2003-04-05 21:20:44.125 BlueCabbie[1955] 1, 80, 50, P
2003-04-05 21:20:44.384 BlueCabbie[1955] 1, 95, 5f, _
I expect the K and P data to be returned, But I do not understand where the _ (0xf5) is coming from. This looks a lot like a rollover problem to me. Hence the hardware question.
Also, I the K and P keys were pressed many more times than the log shows. When I press them slowly, I get every one. When I press them quickly, I get the bad data and some are totally missing. -Chuck-[/code]
// checkKeyboard
- (void)checkKeyboard
NSAutoreleasePool * pool = [[NSAutoreleasePool alloc] init];
char key; // Input buffer
ssize_t numBytes; // Number of bytes read or written
[NSThread setThreadPriority:0.2];
while (TRUE) {
if ([self myCheckRead]>0) {
numBytes = read(fileDescriptor, &key, 1);
NSLog(@"%d, %d, %x, %c",numBytes,key,key,key);
[NSThread sleepUntilDate:[NSDate dateWithTimeIntervalSinceNow:0.001]];
[pool release];
Re: GLK24064-25-VPT-E What is the Max keypress rate?
faster then you can press.WildRice wrote:Using a GLK24064-25-VPT-E .
check out the GLK24062-25 manual for debounce settings. The default is 8. (I can't tell you in ms because I'm having net problems)Is the keypad debounced? If so, what is the bounce delay?
It will either not send a keypress or send a strange character.(How) Does it handle rollover (two keys pressed at the same time)?
yes and no, on default it send the ASCII character out right away, but you can turn on poll for keypress, and then the LCD has a buffer of 10 keys.Does it buffer keypresses in any way? I know my serial port buffers incoming data, but does the board do any buffering?
Humm... I can press pretty fast!Henry wrote:faster then you can press.WildRice wrote:Using a GLK24064-25-VPT-E .
RTFM!Henry wrote:check out the GLK24062-25 manual for debounce settings. The default is 8. (I can't tell you in ms because I'm having net problems)WildRice wrote:Using a GLK24064-25-VPT-E .
5.5.7 Set debounce time (254 85 [time])
[time] is in increments of 6554 microseconds.
This command sets the time between key press and key read. All key types with the exception of latched piezo switches will "bounce" for a varying time, depending on their physical characteristics. The default debounce time for the module is about 52 mS, which is adequate for most membrane keypads. This time equates to a setting of 8 using this command as there is a debounce time resolution of 6554 microseconds.
yup, But I'm not really allowed to say thatWildRice wrote:Using a GLK24064-25-VPT-E .
RTFM!Sorry. I must have missed that. 52ms is the default. I will have to play with that parameter a bit. -Chuck-
as for the keypress speed... I'll find out for you.
