Cannot power it up?
markballance
Cannot power it up?
Post by markballance »
I have just received my new LK202-25 V WB
When I power up the unit with the supplied 5v cable all I see if I look very very closely is all the pixels are slightly on but that’s it. No flashing courser or model number or anything.
If I connect the serial cable the top goes out and only the bottom line is on.
When I say on, its not bright its just you can make out the pixels which you cannot when there is no power.
Can anybody help please? :-?
markballance
Sorted - Supplied giving bad info
My supplier sent a 5V power cable but the device needs a 12v supply.
Thanks.
Hello...
According to the part number that you provided, LK202-25-V-WB, it is a 12 Volt unit not a 5 Volt unit. If you are powering via a power supply make sure you consult your manual on how to convert to a proper 12 Volt cable.
