Faceplate assembly for USB display?
Airshark
Post by Airshark »
Question - I've purchased an LK202-24-USB-WB, and I now realize that I'm not able to mount it and have it look as professional as I'd like (I've overestimated my skills with a Dremel). So I'd like to get a bay insert kit for it. Plain black, no keypad. Is the B2021 the right choice? Clearly I don't need the serial cable. My understanding is that this faceplate is black with clear lexan over the display area. Is this true, or is the face of the display flush with front of the faceplate, or...?
In any case, is this the right part to mount an LK202-24-USB? If not, what is? And can I buy an extra one of those USB cables with the internal motherboard USB connector end from you? It should work great with another bay device I have that currently has to string a cable outside the case.
Cheese
Bit-Tech.net
Bit-Tech.net
Re: Faceplate assembly for USB display?
Post by Cheese »
Airshark wrote:Que Is the B2021 the right choice? Clearly I don't need the serial cable. My understanding is that this faceplate is black with clear lexan over the display area. Is this true
Yep and yep.
Airshark wrote:And can I buy an extra one of those USB cables with the internal motherboard USB connector end from you? It should work great with another bay device I have that currently has to string a cable outside the case.
No I don't think you can, I made my own ;)
Rob.
