First, with the cable plugged in, how thick is the unit from front to back?
Second, is it possible to lower the GPO output to 7 or so volts via software? I'd really like to use this to replace my baybus, and simple on/off action is too basic for my liking.
LK204-25PC Questions
linear - Would it be possible to create a circuit using a lead from my power supply and a transister hooked to the GPO so that it would only use 1 GPO per fan?
Both - Thanks for the info, I'd still like to know the thickness. It says in the manual, but the picture is too small for me to make out the numbers, and I'm not sure if that includes the seriel cable.
Oh, you just want ON to provide less than 12V? Sure. In fact, the tidiest way would be a voltage regulator. Look at a 7809 for example, which would step you down to 9V from 12. Very easy. A resistor would also work, but you have to actually know a bit about your fan current to spec it. The regulator, just bash it in there and have a nice day, part should cost under a dollar.The Savior wrote:linear - Would it be possible to create a circuit using a lead from my power supply and a transister hooked to the GPO so that it would only use 1 GPO per fan?
