Tested with a Fluke 189 set to Fast Min/Max and it measured 4.9A peak! But the strange thing was that the CC stayed on. I used some longer leads to be able to measure this and also without the meter, the CC stayed on. Took off the extra leads and the CC just flashed again. If I put the longer lead back in, the CC stayed on. Maybe I just have to use the longer leads too....?
Don't think so since I use the normal ones all the time. I just extend them with another set of leads plugged into the connector on the first set of leads.
Maybe it's just the small resistance extra in the second set of leads that does it..?
I think the reason the GPO didn't blow up is because it lasted very short. I had to put it to Fast Min/Max to catch it, otherwise it would only show about 0.22A. Min/Max needs a pulse of 50ms or longer to catch it, while Fast Min/Max can catch it down to 250uS. I was planning to check the duration of the pulse, but I have only an analog scope and it can't do oneshot triggers.
I got it from www.microplex.no, but their website is only in norwegian. If you send them an email (support@microplex.no), they can probably tell you who manufactured them. It's a red 30cm CC from their new supplier. Looks like it came from www.bitsmodding.com by looking at the box.
