l2c
ikis
Post by ikis »
I just want to know how to send I2C commands with a program.
Show I use the rs-232 port and send the the commands just I was using rs232 (using any com)?
thanks
Adrian
ikis@gmx.net
It's almost the same, with the exception of adding a read/write bit and the destination address of the command.
2.2.4 I2C Communications
I
ikis
Post by ikis »
and what about the start and stop bytes
there is an example or something?
I've readed all the documentation of the I2C and the pdf of the lk162-12 and I've not found nothing.
About the acknowledge, should I not implement the ack in I2C according the limitations that you write?
The I2C interface to the display is the normal I2C, start and stop bits... the only difference is we add an extra read/write bit. Nothing else is different.
ikis
Post by ikis »
And what about the ack,
should I implement it according to the limitations tha you wrote?
of course.
ikis
Post by ikis »
I understand, and about the ACK, START, STOP codes, in the site
http://www.ping.be/~ping0751
I can't fount nothing, even in the product specification, where I can found it?
I don't understand your last post.
ikis
Post by ikis »
I only want to say is that I can't found the START, STOP, ACK codes.
