I'm new at this
nooyawkah
Post by nooyawkah »
I'm a bit confused about the differences between some of your products.
First, I'd like an opinion on getting an LCD or VFD. My PC is kept in a small room, maybe 10X10 (on display, of course). There is some sunlight but coming from the back and side of the case. Because of the room size, no one can ever see the PC from more than 10 feet away and no LAN parties for me. That said, is the LCD sufficient or will I soon want a VFD due to the brightness of the display? This ALWAYS happens to me when I buy on impulse.
2nd, if I do go with a VFD, what is the difference between "MODULE: Beige Bay Insert BVK202A PRICE: $155.00" and "BVK202A Beige with standard cable $132.75?" Is the latter without a drive bay insert?
And lastly, blue is prominent in my case. Would I be happier with the blue filter?
Thanks in advance. I'm just trying to buy this only ONCE. :-)
1. If you use a VFD and a filter it will look good... VFDs with no filtewr will wash out, be totaly unreadable... but with one it will look fine (especialy with the gray one, but blue should be fine too).
2. The BVK202A-4BR has a nicer cable set... see this review for the cables...
http://www.hitechmods.com/reviews/LCD/B ... 202a.shtml
The lower priced one just has a 4ft serial cable...
