problems fitting the blk202A on my new case
Guest
Post by Guest »
i have a chenming 901A case.chenming makes the antec & chieftec cases.the 901A looks just like the antecSx1240.the trouble i am having is with the drive rails that you use to install cdromcdrw,etc. i am trying to get them to fit on the lcd rails but still give me enuff clearance to slide in.does anyone have a chenming or antec case & they installed an lcd.any help greatly appreciated.thnx
Akiry
Post by Akiry »
I had no problems installing mine into my antec 1000 using the the case drive rails. It is alittle tight hightwise but fine widthwise. I also had some usses with the drive rails not stopping at the proper spots but that was MY case I jsut had to bend the rail stopping tab type deal thingies in a bit more.
Guest
Post by Guest »
thnx for reply akiry.stupid me had the rails on backwards.i have it mounted as far forward as it can go but it is about 14 inch short of sitting flush with the baybus.thnx again
