Can i mount a harddrive behind this pc bay insert?
BrianW
Post by BrianW »
Noob to LCD's and can not wait to get into it. I would like to just mod the front bottom of my case, unfortunately it is curved. I have decided to go with a double bay insert. http://www.matrixorbital.com/products/bvf2041.htm I have removed the hard rive bay on my case to allow more room for my watercooling system. I need the 5.25 bays for hard drives. Can i mount 2 hard drives behind this insert?
Thank you.....
<font size=-1>[ This Message was edited by: BrianW on 2002-03-27 16:15 ]</font>
BrianW
Post by BrianW »
Bumb
PLease give this post some thought....
Thank you.
Mat-Moo
Post by Mat-Moo »
If you where skilfull enough, you could cut out the whole area where the LCD will protude, spray (us use the black plstic sticky surrond) to the fron part of the LCD and trim it down, then glue from the inside the LCD display - obviously this would nee to go in the centre of the curve otherwise it could look a tad odd. Other sugestion is maybe to put it in the top of your case or side?
Mat-d-Rat has a good idea, as well, if you use the bracket...
the B204 will use the front screw holes for it self. Take te HD adapter bracket and cut away the section which would screw to the front, and then just use the back screw holes for the HD.
_________________
<font size=-1>[ This Message was edited by: Henry on 2002-04-01 22:56 ]</font>
