BAD Print UTF-8 in GTTProject
djvoss
Post by djvoss » Sat Jul 19, 2014 2:18 pm
When I use Print UTF-8 String the RAW DATA shows the following: 255 37 and no data ( char data ). No chars are displayed on the screen. I did proceed this command with a load font, set font, and set font size and color.
Help please
Don
Tino
Re: BAD Print UTF-8 in GTTProject
Post by Tino » Mon Jul 21, 2014 9:30 am
Hi Don,
How are you sending the data to your display?
Are you sending a UTF-8 formatted string when you send the data?
Thank you
Martino
Martino DeLeon
djvoss
Post by djvoss » Mon Jul 21, 2014 10:26 am
Martino,
I am using your GTT Project Software. When I try to use the Print UTF-8 command, the raw data displayed has no char data. After execution the interaction panel also shows that no data is send after the 255 37 . If I use the other Unicode String, it works. however I would like to setup an ascii string.
Don
Tino
Post by Tino » Mon Jul 21, 2014 10:58 am
Hi Don,
I will look into this for you. In the mean time is it possible you use the "Print Unicode String" command?
Thank you
Martino
Martino DeLeon
