GLK240128-25 memory problems
gstlachi
Post by gstlachi »
I´m uploading 12 images to the LCD. The images are uploaded correctly, but, when i upload 1 type of font all images uploaded before are erased, but the fonts remains. At the same time, when first, i upload fonts and after that the images the fonts are erased and the images remains.
The images are uploaded from ID 1 to ID 12, the font are in ID 1 and Im using the MOGD# Software v1.1.5. Am i overriding locations?
Can you help me with this.
Kind of regards
Tino
Re: GLK240128-25 memory problems
Post by Tino »
I understand you are having an issue with uploading.
What PCB Revision is your GLK240128-25?
Also what firmware are you using?
Thank you
Martino
Martino DeLeon
gstlachi
Post by gstlachi »
Hi Tino,
Thanks for helping.
The LCD has PCB R4.0 printed and I'm using firmware 8.3. I'm noticing that only the image on first location (ID 1) is erased when i upload a font and viceversa only first positions.
Tino
Post by Tino »
Please upgrade your firmware to 8.4 this may help. You can find the firmware upgrader at:
http://www.matrixorbital.ca/software/GLT%20Series/
Please let me know if this works.
Martino
Martino DeLeon
