OK, how do I get the Typhoon to work? Bad instructions!
NeilF
Post by NeilF »
OK, so trying to get a Typhoon to work on Vista 64.
Following the instructions as posted here - http://www.lcdforums.com/forums/viewtopic.php?t=3763
1 - Driver Core = Dead link! Great start!
2 - LCD Studio = Fine, installed it, but no good without (1) I assume.
3 - .Net 2.0 = I assume you do not need to do this with Vista 64 SP1?
Would be nice to be able to use the typhoon :(
Actually with your GX you should have gotten a letter with the correct location of the Drivers. If this wasn't included please let me know.
The latest drivers you can find here the current latest verison of the drivers are the Aug 2008 software pack for the GX
Ps. no need to cross post, its a relativly small forum, I do read all of it :)
NeilF
Post by NeilF »
Ray wrote:Actually with your GX you should have gotten a letter with the correct location of the Drivers. If this wasn't included please let me know.
Try some of the links in your own sticky - http://www.lcdforums.com/forums/viewtopic.php?t=3763
I know the sticky is wrong (or actually was, i just fixed it) but was there a letter included with your GX? Cause if there wasn't I need to take action on that.
Fenners
Post by Fenners »
It does work fine on vista 64, although the need to let defender run the program is a pain but bearable.
I have created a signed version of LcdStudio 806 (same version as in the aug'08 rev1 software pack) just copy the exe file over the old copy (no installation required) and see if that makes defender happy. Please report back any success or failure
NeilF
Post by NeilF »
Ray wrote:I have created a signed version of LcdStudio 806 (same version as in the aug'08 rev1 software pack) just copy the exe file over the old copy (no installation required) and see if that makes defender happy. Please report back any success or failure
OK! Thanks! Will give it a go and let you know...
NeilF
Post by NeilF »
Still fails I'm afraid! Windows Defender refuses to run it at startup.
