Unfortunately I have two very loud high-performance 120mm Panflow fans for my water-cooling setup.
The MX2 series appears to have 3x 3-pin RPM monitoring connections for fans, as well as a few GPOs? or is that the same thing and I am mixing it up?
I want to be able to hook-up the two 3-pin 12v 0.6amp fans to this unit. These fans do not support RPM monitoring, will LCDC still be able to adjust their speed based on voltage alone?
Also, without using thermal probes, is it possible to just setup events that read temperature info from MBM5 on when to adjust the speed?
Ideally I want the software to throttle down the fans once windows + LCDC boots and is running fairly idle (listening to music, surfing the net, etc...) And for it to automatically speed up the fans to max performance once I kick up a game and things start to get hot
I am still new to this
