I am working on a project that is to use a vk204-25v (serial VFD) and attach to a usb serial adapter. My question is can i presume that LCDC will be able to connect to the com port the device (adapter) attaches itself too or must i connect to the device over com ports 1 or 2 only? I can force the device to connect to any com port and it will attach itself to the first available one (com1 assuming its not in use) but i figured i should ask first.
ohh and there is a special reason i am not using a usb vfd
If you are using a USB adapter, it will create a virtual com port for you, so you are not limited to com ports 1 or 2. You must also have the USB adapter's drivers it to work. LCDC will then treat that port like any other port.
I have a similar problem. Before loading LCDC I also had TDK Bluetooth dongle. With Bluetooth loaded it moved all the new com port assignments into the COM50 range. When I installed LCDC it set itself up as COM56. Now each time the PC restarts LCDC says it cannot communicate with COM2. When I go in to configure/test the panel, it correctly identifies it as on COM56. After restarting I have to go in to the test protion then can imediately back out, without sending the panel anything and it will be working again. This is really an annoyance and I would like some suggestions to fix it please.
Have you tried loading the new driver yet? You can download the most recent driver at http://www.lcdforums.com/forums/viewtopic.php?t=1016 . The newest version was released on February 7, so you might not have it yet.
Try this, and see if this improves your situation.
Didn't help! LCDC still tries to access COM2 on startup even though MX2 is on COM56. During the detection phase it scans COM1, COM53, COM54, COM55, COM56, so it knows how to find the panel. It just won't keep the configuration.
BTW COM53-55 are the Bluetooth emulated serial ports.
