ok heres my situation, i am building a new computer in the next couple days and i would love to implement an LCD display.
hardware i have already purchased is as follows:
ASUS A8V deluxe
AMD64 3500+
1GB (2* 512MB matched DDR500{PC4000} Kingston hyperX)
Acrylic Clear Case
Now i am not to sure about what all connections are on the ASUS motherboard as far as internal, it's pretty much a top of the line board and i am sure i can hook one of these displays up fairly easy, but i am not quite sure what connectors and cables i will need to get my LCD fully functional. Also i am planning on getting 2 UV cold Cathod lights and would like to hook them up thru the LCD displays i have a few questions and will try to make it easy to understand what i am after.
Trying to decide between the MX431 and the LK204-25-GW
1.... Is there any difference between units that communicate over USB vs units that communicate via RS232 or I2C, Is one more preferred amongst the people who order them, is one faster or easier to hookup then the other.?
2.... How do each of those units derive their power? I assume but really have no idea that the MX431 draws power from the USB as well as data communication, Does th LK204-25-GW need a power connection as well as the data connection?
3.... If i hookup the MX431 (Via USB) i would preffer to not have any cables comming out the back of my PC to connect the unit. Would i use this cable to connect to the usb internal interface on my mobo
or would i use this cable to connect all internally
or would i use the USB a-b cable....
(i am not sure but i dont think my mobo will have any "regular" usb ports internally, i think it supports usb pin out... but not the "normal socket" that a regular USB (A?) cable would slide into).........?
4.... last question i promise, Whats the best way to wire a pair of cold cathod lights to the matrix orbital? will one device power them better then the other. I assume they get hooked up to the "GPO's"..... and will them being turned on almost 24/7 dim the display at all or cause to much strain on the power out from the unit?..
i hope i didnt confuse the hell out of everyone.
i look forward to building a new PC And showing off to everyone a clean clear LCD display. Also with an acrylic case wiring cleanliness is a must and the less wires i have running all over the place the better.
for future refernce a picture of the back of each unit would be a great thing to have on each units sales page.
thanks for the read
orb
p.s. sorry to bore you if all these questions are answered somewhere else, i looked through the entire forum and guides/faq pages, sorry if i missed the answer to my question.
