hello.has anyone used this type of adapter before to use a mo display.
i am not sure how a person would set the com rate etc,when using a usb port.i have looked around but have been unable to find any info on this.
thnx for help
using a serial port to usb adapter with a blk202A
Hello...
We are currently in the procees of developing our own converter board. The converter board we are developing will have the ability to do the following..
USB <-> RS232
TTL <-> RS232
USB <-> TTL
We are in the final stages of testing...as for a release date, that's yet to be determined!!
USB <-> RS232
TTL <-> RS232
USB <-> TTL
it should work fine, as most usb -> serial converters are 19.2K by default... all it will do is create a new Virtual COM Port on your system. All you have to do is point the software at the new COM Port, just don't unplug the cable while the software is running... it's not pretty.jtf2 wrote:thnx for reply miles.i went out and bought an iomega usb to serial port adapter.ill see how it works
