Fan Control
Worf
Fan Control
Post by Worf »
Can I use If statements to control my CPU fan?
I am asking because I dont like how when using the varibale control when CPU usage drops to 0% the fan stops spinning.
Should I have posted this at the LCDC site, if no one knows?
FrankFuss
Post by FrankFuss »
If you are using the LCDC GPO PWM/RPM control, you just enter a Mimimun PWM value greater than zero on the Configuration screen and it will not go below that value while LCDC is running. You should enter a non-zero Start/Stop setting and power-up value for the CPU fan. I use 25% for Minimum PWM and a 50% Start/Stop setting and power-up value for my CPU fan.
And if you are concerned about the fans not running at start up, please see the following link...
http://www.lcdforums.com/forums/viewtopic.php?t=1465
Mat-Moo
Post by Mat-Moo »
FrankFuss wrote:If you are using the LCDC GPO PWM/RPM control, you just enter a Mimimun PWM value greater than zero on the Configuration screen and it will not go below that value while LCDC is running. You should enter a non-zero Start/Stop setting and power-up value for the CPU fan. I use 25% for Minimum PWM and a 50% Start/Stop setting and power-up value for my CPU fan.
This is spot on - just make sure you set a minimum level you want lcdc to set your fans to, so that they don't stop spinning.
## # Mat # ##
http://www.lcdc.cc
Matthew@DPS.uk.com
DPS Ltd. (Not MO!)
kidgambino
i cannot even get that far
Post by kidgambino »
I setup my MX222 and the GPO's wont even recognize my fans. They are running and i have the external power plugged in but i can read rpm, or control them in any way. I am not using temp probes. Any suggestions?
MX222 USB
Hello..
Can you communicate with the display? ie. turn contrast up/down, backlight off/on?
kidgambino
fan control
yes, i can run all of the default displays. I even setup the GPO's in the config menu of LCDC.
MX222 USB
