GTT Designer requires admin privileges on every launch?
Posted: Thu Nov 14, 2019 9:01 am
by ehrnam45
Every time I open the designer, I'm prompted for an admin password. Is this intentional?
A quick search gives me the impression that it's caused by not having a MS verified publisher certificate, but I also have a very oppressive IT environment at work so that may be related. Turning off UAC isn't an option. Anything else I can do to work around this?
Win10 Enterprise 1803
Re: GTT Designer requires admin privileges on every launch?
Posted: Wed Nov 20, 2019 9:57 am
by Ray
The gtt designer is actively requesting elevated privileges, the way the designer communicates with the unit requires this. If you drop us a line at support@matrixorbital.ca we can send you a copy that doesn't request these privileges, however, the automatic deployment functionality will not be available in this version.
Posted: Wed Nov 20, 2019 10:43 am
by ehrnam45
Understood. I haven't received the display yet, was just trying to take the designer for a test drive. I'll see if it's a significant issue and get back with you if I need the other version.
