Can't deploy to flash card on GTT29A
pblase
Post by pblase »
I am trying to deploy the GTT29A example project and get the following error when it tries to copy the files out to the display:
GTT error.jpg (25.31 KiB) Viewed 30569 times
It creates the directories, but no files are actually in them.
Re: Can't deploy to flash card on GTT29A
Hi pblase,
Welcome to the forums!
Do you mind zipping up your project and sending it my way?
I can take a deeper look at the project here.
Dan
pblase
Post by pblase »
It's the demo project that I downloaded from your site. No changes.
GTT29_DemoProject.zip
(7.84 MiB) Downloaded 3208 times
pblase
Post by pblase »
Ah, discovered the problem. GTT Designer can't handle it if the project directory is encrypted under Windows, which it was. When I removed the encryption from the directory the problem went away. Suggestion: since some of us make a habit of encrypting directories containing important files, such as product designs, this should be fixed.
Hi Pblase,
I have added your suggestion to the list of GTT Designer improvements. We'll be looking to implement encrypted file/directory compatibility sometime in the future.
