C++ using customer characters? OK204-25-USB
mascenzi
Post by mascenzi » Tue Apr 30, 2019 1:30 pm
What am I missing? So I've been messing with my OK204-25-USB for about a week. I've figured out the communication on most of the functionality. Creating and using bars, medium/large numbers, moving cursor around, displaying text, etc. However, creating custom Characters I'm confused.
Lets look at the command for Creating a Custom Character {254, 78}. Here you supply the ID for the character and 8 bytes that will represent a 5x8 batch of pixels.
Can I then use that custom character without saving it? Or do I have to save it first? I understand if I switch bank or power down that character will be lost, but can I use it util either of those occur?
Now lets say I have to save it first. No problem. So I'll use Saving Custom Characters {254, 193}. Here I supply the bank I want to store it in, the ID of the custom character and then 8 bytes that, again, represent a 5x8 batch of pixels.
Whats the reason for having to supply the 8 bytes again if I've already created it previously? Why couldn't I just supply the bank I want to store it in and the ID I assigned to the custom character when I used the command {254, 78}?
Ok lets say I save it in bank "0" and ID "1". How do I use it? How do I send it to the display? I don't see any commands to use a custom character in the manual? Am I overlooking it? I see how to load a bank of custom characters [254, 192], but once I have the bank I want, how do I call say ID 4?
Re: C++ using customer characters? OK204-25-USB
Post by Daniel Divino » Tue Apr 30, 2019 4:31 pm
Hi mascenzi,
It won't be necessary for you to save your custom characters in order to use them.
Once a character is created, you can draw it on screen it by sending the assigned custom character ID to the display.
I have a pseudo code example demonstrating how to use custom characters below:
ClearScreen(); //Clears the display
CreateACustom(0x00, 0x0A, 0x0A, 0x0A, 0x00, 0x00, 0x11, 0x0E, 0x00); //Creates a custom smiley face character with an ID of 0
WriteString(HelloWorld); //Writes 'Hello World' to the display
WriteValue(0x00); //Sends Hex value 0x00 to the display. This will draw the custom smiley face character on screen
Using saved custom characters will follow a similar procedure:
SaveACustom(0x00, 0x00, 0x0A, 0x0A, 0x0A, 0x00, 0x00, 0x11, 0x0E, 0x00); //Saves a custom smiley face character with an ID of 0 in memory bank 0
LoadCustomCharacters(0x00); //Loads custom character bank 0
Hopefully this helps clarify how custom characters can be used.
If you have any other questions or concerns, please let me know!
mascenzi
Post by mascenzi » Wed May 01, 2019 6:14 am
Daniel,
Thank you so much for following up with me. I'm glad to hear that I can skip the saving part and just store them in my program and send them as I need them. This gives me a lot more options for creating imagery on the display.
However, I'm still not sure what commands I'll need to send. In your pseudo code you give:
WriteValue(0x00);
When I'm writing the software the first three are easy. The commands I would use are.
unsigned char clearScreen[] = {0xFE, 0x58};
unsigned char customChar[] = {0xFE, 0x4E, 0x0A, 0x0A, 0x0A, 0x00, 0x11, 0x0E, 0x00};
unsigned char message[] = "Hello World!";
and I would send each of them this way.
WriteFile (my_port, &clearScreen, sizeof (clearScreen), &bytes_written, NULL);
WriteFile (my_port, &customChar, sizeof (customChar), &bytes_written, NULL);
WriteFile (my_port, &message, sizeof (message), &bytes_written, NULL);
but with the WriteValue(0x00);
Would that just be
unsigned char value[] = {0x00};
or is there a command that I need to send like
unsighed char value[] = {0xFE, 0x??, 0x00};
Post by Daniel Divino » Wed May 01, 2019 9:41 am
Hi Mascenzi,
You should be able to send either of the following:
WriteFile(my_port,"\0x00", 1, &bytes_written, NULL);
or
unsigned char b = 0x00;
WriteFile(my_port,&b, 1, &bytes_written, NULL);
No command will be needed to draw the custom character on the screen.
mascenzi
Post by mascenzi » Thu May 02, 2019 5:27 am
Daniel,
Thank you for your time and help.
Post by Daniel Divino » Thu May 02, 2019 8:38 am
No worries Mascenzi,
Let me know if you have any other questions!
Users browsing this forum: No registered users and 23 guests
