5 1/4 Mounting Bracket
nbeekman
Post by nbeekman »
Hello, I am having an issue install the 5 1/4 bracket. The screw holes do not align up with the case frame. Has anyone used a Hard Drive bracket the works? This frame has only center holes not the dual like the mount.
HELP
Thanks all :roll:
Norman
5 1/4 PC Bay Insert
Hi Norman,
Sorry to hear that you are having trouble with your installation. If you could get the bracket model number and PC case model I will have better understanding of your problem, and can start working on a solution here in the lab.
nbeekman
Re: 5 1/4 PC Bay Insert
Post by nbeekman »
The chassis is a Fox Conn TW-01 which can be viewed at http://www.foxconnchannel.com/product/C ... -us0000008
the Matrix Adapter is the B202
Hope this helps and thanks for the response.
5 1/4 PC Bay Insert
Hi Norman,
Thanks for getting those details. I have contacted one of our local suppliers to try to get a similar case, but unfortunately they do not carry the Fox Conn brand so I am unable to be much more help at this point. Short of modifying the mounts yourself, the only advice I can give you is to keep checking the forums here to see if anyone else has had a similar experience.
Good luck with your hard drive mount, I hope you can get it worked out,
