Just replaced an external MX212 for an MX232 simply by plugging it in.
Placed itself on an other comport wich is no problem, however the backlight stays very bright at 100%.
When Test Display with the command Backlight Intensity and sending the selected command it responds to the values set in Configure LCDC.
Even when making an Event as Backlight on Start with Action: Off it will respond. On Action: Reset it is not responding.
But on starting the display it still is on the 100%.
Hope some of you smart guy's can help me. Regards, Jan
Backlight Intensity
Hi Jan,
Try using uproject which can be downloaded at http://www.matrixorbital.ca/software/so ... /uproject/
You can set and save the default brightness of the display with that application.
- LCD Geek
