I'm trying to set up my fans to incress and decress speed by pushing a buttion on my keyboard in config/test i have it set to manuel set in screen builder start stop setting 100. In screen bulider - events i have fan on event sys-->on keypad press and i'm using Q then in action i have Gpo-->advanced-->Incress pwrn Gpo 1 and 10 for the rating incress. For fan off i have all the same settings excecpt for action Gpo-->advanced-->Decrease Pwr using kepad W
What am i doing wrong? I can't turn the fans off.
I noticed in events some of the things that are in there like to open IE use keypad U that don't work?
Can't get fans to come on and off with LCDC?
- LCD Geek
- LCD Geek
When opening the virtual display you can configure ABCDE to give functions
like A=P (in my case an MX2) and it will perform an email check.
Also try the plugin HOT (hotkeys to make keyboard shortcuts).
Personally I never tried this.
I don't know which screen you use but I suggest to make B=K(up) and
C=L(down). Disable in Events keypad up/down as they are standard to
in/decrease volumes. Regards, Jan
- LCD Geek
- LCD Geek
Glad to see it worked out for you! There are numerous variations to fit your
personal needs. I learned from this also and linked the hotkeys to a screen showing both % and rpm. One fan needs two additionel events for the up and down saying: ->Disp go to Selected Screen. Create a screen that visualise the results like the one to be found in the Screengallery.
Regards, Jan
Regards, Jan
