The indicator leds on the low GPO's are all working on startup.
When the screens are cycling trough they are responding to the commands.In table 31 of the manual it says they must be standard Off.
With LCDC comes an Event called Digibus and in the Command Selector it says GPOOn,RPM. Do I have to make changes here?
This only happens by one of my three MX2's controlled by LCDC v1.06.
GPO Low
- LCD Geek
Thanks again, TomTom wrote:Try reprogramming the GPOs in the event. I ran into this problem once before, and I reprogrammed the event . It worked afterwards.
:D
I created 3 Events saying: Sys>On Start, Action: GPO>Off and numbers 4,5,6. I was afraid to ruin my device but this does the trick!
They will respond to the commands when LCDC cycles through.
Yours sincerely, Jan
