just got the mx213 tried to install it right quick, everything installed fine except the serial usb driver, i looked over documentation for what little time i fiddled with it and documentation pointed at a diffrent file for the driver then the one the software tried to install, i installed it the installers way, didn't work, went back tried to point it to hte file that the documentation showed and it would accept it any advice? using XP prof
EDIT: ill add the file names when i get off of work, just thought i'd throw it out there now to see if someone already knows what im talking about:p
Installation issues
FILE NAMES
File Names: the one the installation software is asking for is ftser2k, the one the html page refrences when showing step by step setup is ftdiport.inf, i dont know if this is causing hte problem again its just not installing the serial usb on xp
also the exact error message is
the name is already in use as either a service namer or a service display name
Hello...
Try the suggestions at this link and let me know how you make out: http://www.lcdforums.com/forums/viewtopic.php?t=1016
As for registering LCDC you must go to the site on the peice of paper with your unit (Mx quick install guide) and enter your key (the one that is on the eCD)...then just follow the steps...
