Hey everyone... I though I would show you the newest LCDC plugin. It's called Fraps. What it does is allow you to see the Frames Per Second on any Open GL or Direct X games. As well as see other little tid bits of information, like total frames and so on. With this, LCDC got a new plugin...
Now some LCDC shots... (please note, this is the hardest LCD to take a picture of, it looks much better in real life)
Showing you the current FPS and the screen resolution in the game...
This screen shows you the game you are playing and the CPU load on the bottom
Last, Here is a 20 second FPS graph. It uses 3 lines, showing a range of 0FPS to 30FPS at the top. The bargraph updates every 1 second giving you a nice 20second FPS dipsplay. (the update time can be between 1second and 60seconds..
Stop by the LCDC site to grap it Enjoy!!!
New LCDC Plugin!!! FPS on your Fav. Game!!!
- LCD!
The clue is in the first post.
Set it up as follows:
Line 1: [%FON41%[#$FRAFra]%] Screen Res.
Line 2: [%FON42%[#$FRAFra]%]
Line 3: [%FON43%[#$FRAFra]%]
Line 4: [%FON44%[#$FRAFra]%] FPS
I haven't inculded the bit to give you the res, as I don't use this plugin, so don't know exactly what it's called.
- LCD!
