LK204-25PC Display, Standerd Floppy Cable?
trippin
Post by trippin »
I just bought a LK204-25PC from Matrix Orbital's store. Is this the only display that makes use of a unmodified floppy power cable? Has this model been fixed so that there are no more gpo bugs? Have any new features been added?
YES, YES, and YES!
Seriously though... The PC is the only unit that uses an unmodified floppy power cable and the GPO bugs have been fixed. As for new features; the most used would probably be variable brightness control, and for the more faint at heart the TTL, RS232 select along with the memory chip lock down feature.
_________________
RMA Department
<font size=-1>[ This Message was edited by: Miles on 2002-09-23 15:32 ]</font>
trippin
Post by trippin »
What the TTL? Neato i cant wait till it arrives! Dont worry ill post some pics!
CyPher
Post by CyPher »
if you are using lcdc (which you definitily should) make sure you grab the latest version 1.02.20, and select the lk204-25-pc-rev1-2 definition file...that will give you access to the variable backlight withen LCDC...
