EVE Screen Editor (ESE) 4.6.0 RC1
https://www.matrixorbital.com/index.php ... t&did=1812
Version 4.6.0
RC1
Feature updates:
Х Improve inspector.
Х Improve the registers window.
Х Improvement on RAM_CMD window.
Х Add an inspector window for RAM_CMD.
Х Add one more section for exporting projects.
Х Add one more example project "Circle Line".
Х Add the support of IDM2040-7A board in export menu.
Х Apply the anti-aliasing effect to the inner circle in the "stencil fanshape" example project.
Х Add NOP into register MACRO 0 and 1.
Х Add one more chapter Work with EAB in the user guide of ESE.
Х Add button in toolbar to toggle on/off alignment behaviour.
Х Enhance 3rd party lib usage.
Х Change font size of Coprocessor and Display List editor.
Х Keep one instance of inspector window when it is poped up.
Х Add VM880C module (480x272) submenu in the export menu.
Х Support screen rotation by configuring the REG_ROTATE without touch coordination system rotation.
Resolved issues:
Х The Properties window should not pop up when changing steps in the Controls window
Х A widget cannot be deleted if its command is the last one in the Coprocessor window.
Х Unexpected behavior when user drops a new Content item with the Examples.
Х Toolbox does not resume from display list mode to coprocessor mode.
Х The source file should be relative file path.
Х The app crashes when the line limit for the Coprocessor/Display List editor is exceeded.
Х The error popup does not close when we already have a content item.
Х Unable to build the export project successfully with FT81X devices.
Limitation:
Х When the REG_ROTATE is changed, the emulator does not allow for item selection on the newly rotated screen. Instead, users must select items from the previous position.
