Drivers not signed on Windows 7 64-bit?
Punslinger
Post by Punslinger » Tue Mar 15, 2016 9:29 pm
Hi. I recently purchased an MX312 for my new computer, but Windows 7 is giving me problems with the drivers. When I try to install them, Windows gives me a Code 52 error and complains that it can't verify the driver signatures. Checking the driver details from Device Manager shows that the files are unsigned, but checking the Properties for each file in Explorer shows that all of the files are signed!
I downloaded the latest drivers directly from matrixorbital.ca, unzipped the folder, and installed the drivers by going into Device Manager, right-clicking on the MX2/MX3/MX6 entry, and selecting Update Driver Software and pointing it at the unzipped drivers folder. Is there a step I'm missing in the installation? Some configuration change I have to make? Why is Windows refusing to accept the file signatures?
I'd really appreciate any help you can give me. I don't want to be reduced to pressing F8 every single time I boot the system just to make the display work.
Re: Drivers not signed on Windows 7 64-bit?
Post by Clark » Wed Mar 16, 2016 8:49 am
Hello Punslinger,
You are correct, our latest USB Drivers are certainly signed. That said, the problem may lie in how they are signed.
Microsoft has recently completed an upgrade from an SHA-1 secure hashing algorithm to SHA-2 (as of January 1, 2016). Our drivers are currently signed using the latest SHA-2 algorithm, so older machines may not recognize the hashing algorithm. You can find more information in this Microsoft SHA article.
To resolve this issue, I would recommend ensuring that your Windows 7 install is up to date. Specifically, please ensure the Security Update for Windows 7 for x64-based Systems (KB3033929) is installed. You can find more information in this Microsoft KB3033929 article, and a download link at the Microsoft KB3033929 Update site.
Punslinger
Post by Punslinger » Wed Mar 16, 2016 7:08 pm
Updating Windows worked, and I was able to install the drivers. Thank you!
Trytin
Post by Trytin » Wed Feb 22, 2017 11:31 pm
Upgrading to WIndows 10?
You can click here for the Wealthy Affiliate.
Post by Daniel Divino » Fri Feb 24, 2017 3:31 pm
Hi Trytin,
I run a Windows 10 PC at the office, and the USB drivers work fine for me. The Windows 10 OS will be SHA-2 compatible from factory. If you are installing the drivers on your Windows 10 PC, you should have nothing to worry about.
Dan
Users browsing this forum: No registered users and 10 guests
