Bug in 64bit Driver on Windows?
niston
Post by niston » Thu Sep 25, 2014 8:11 pm
I'm developing an embedded device and use the GLK19264 USB Display as an UI. The software is written in C#.
When running on Windows (.NET 4.0), this will happen after a brief period of time:
- Display stops updating
- 9 out of 10 times, the display backlight starts flickering like mad
- The virtual COM port locks up
Subsequent writing to the Port raises an exception:
System.IO.IOException was unhandled
HResult=-2147024865
Message=A device attached to the system is not functioning.
Source=System
StackTrace:
at System.IO.Ports.InternalResources.WinIOError(Int32 errorCode, String str)
at System.IO.Ports.SerialStream.EndWrite(IAsyncResult asyncResult)
at System.IO.Ports.SerialStream.Write(Byte[] array, Int32 offset, Int32 count, Int32 timeout)
at System.IO.Ports.SerialPort.Write(Byte[] buffer, Int32 offset, Int32 count)
at sndchk.Display.Send(Byte[] Command) in c:\Users\***\Documents\Visual Studio 2013\Projects\sndchk\sndchk\Display.cs:line 215
at sndchk.Display.DrawBar(Int32 top, Int32 left, Int32 height, Int32 maxWidth, Int32 percent) in c:\Users\***\Documents\Visual Studio 2013\Projects\sndchk\sndchk\Display.cs:line 302
at sndchk.Display.set_LevelLeft(Int32 value) in c:\Users\***\Documents\Visual Studio 2013\Projects\sndchk\sndchk\Display.cs:line 65
at sndchk.Program.Main(String[] args) in c:\Users\***\Documents\Visual Studio 2013\Projects\sndchk\sndchk\Program.cs:line 258
InnerException:
After stopping the debugger, Visual Studio will not respond until the USB connection to the display is severed.
The exact same software runs flawlessly for hours on a Raspberry Pi (ARMv6 Linux, mono), with the same display connected to it via /dev/ttyUSB0.
So I suspect there's a problem with the 64bit Windows FTDI driver that I'm using (DriverVer=03/18/2014,2.08.30.6).
Is there a newer driver available? On ftdichip.com, there's a download for DriverVer=01/27/2014,2.10.00.
Re: Bug in 64bit Driver on Windows?
Post by Clark » Fri Sep 26, 2014 9:50 am
Hi Niston,
We just released new USB drivers, based on the FTDI 2.10.00 release.
If you have any further trouble with the new version, please let us know.
niston
Post by niston » Fri Sep 26, 2014 1:13 pm
Thanks Troy, that was quick! I will give them a try, although according to release notes for 2.10 the future looks bleak.
niston
Post by niston » Fri Sep 26, 2014 1:51 pm
Yup, that didn't work out.
Installed 2.10 and the problem persists.
Post by Clark » Fri Sep 26, 2014 3:24 pm
Hi Niston,
I appreciate the update and have been running 2.10 here as well, with no issue. This doesn't look like a driver problem.
If you could, I would recommend trying the unit with a different port, cable, or even system if at all possible.
niston
Post by niston » Fri Sep 26, 2014 9:03 pm
Just tried through a hub on a different port, same problem. Will check on a 32bit machine as soon as I get around to it.
But it looks as if I'm not alone:
http://stackoverflow.com/questions/1872 ... ing-c-shar
This is exactly my scenario:
  • System.IO.IOException: 'A device attached to the system is not functioning' on write
  • System.UnauthorizedAccessException: 'Access to the port is denied'. on subsequent writes
Can't help it but my guts telling me it's a driver problem: Something inside is not releasing properly, so the port gets blocked. It is not critical for my project, as everything works fine on the Linux target (as expected, perhaps). However, debugging on Windows would be so much easier if this could be resolved.
Post by Clark » Mon Sep 29, 2014 8:04 am
Hi Niston,
I'm running Windows 7 64bit with Visual Studio 2013 here, and so far no problems. I typically use C# as well, but with minimal threading. If you are able to provide complete and running code to me at tclark@matrixorbital.ca, I'd be happy to test here if necessary.
niston
Post by niston » Thu Oct 02, 2014 2:59 pm
Hey Troy,
Hold a little longer, I will post some source to codeplex pretty soon. Here's a little teaser:
niston
Post by niston » Wed Oct 08, 2014 9:50 am
More teasing :-P
Image Image
Image Image
Post by Clark » Thu Oct 09, 2014 12:40 pm
Looks like your application is coming together nicely Chris!
Users browsing this forum: No registered users and 15 guests
