Serial communication pauses between bytes
Posted: Tue Feb 07, 2012 1:02 pm
by phildoe
I am running my GTT at 115200 over the ttl connection. When the unit is sending a touch response for touch region 1 the communication flows as follows:
<0xFC><pause ~690us>
<0x87><pause ~900us>
<0x00><0x02><pause ~500us>
<0x00><0x01>
Is this typical. It was timing out my hardware FIFO. I have worked around it, however it makes the code a little less pretty and requires 4 RX interrupts versus 1.
Posted: Tue Feb 07, 2012 4:58 pm
by Clark
Hi Phil,
The GTT will require some time to determine what type of event occurred to cause a response to the host, how many bytes that response will be, and finally the data to be sent back. The numbers you have listed do not sound unreasonable.
For your hardware fifo, you might consider a state machine to keep track of what data is expected next, perhaps you can find a way to save a few interrupts.
Posted: Tue Feb 07, 2012 7:42 pm
by phildoe
Hi Troy,
Thanks for the fast reply. I was just making sure I was not missing anything. I have been getting spoiled lately with MCU hardware FIFOs.
On another note I have been using the GTT for a year now as a proof of concept testbed. I would like to use it in my company's higher budget specialty diagnostic equipment(used in-house), however capacitive touch would suit my needs a bit better. Any plans on a capacitive model in the future. I would be willing to fork out more than double the price.
Phil
Posted: Wed Feb 08, 2012 9:07 am
by Clark
No worries Phil,
We're quite flexible with custom units here, if you'd like to swap out the resistive screen for a capacitive one please send an email to
design@matrixorbital.ca outlining what you'll need and we'll find a solution.
