It is currently Mon May 20, 2013 12:52 am
 Page 1 of 1 [ 2 posts ]
Author Message
 Post subject: Is there any need of additional IC (e.g. MAX232) ?
PostPosted: Mon Sep 26, 2011 4:46 am
Is there any need of additional IC (e.g. MAX232) for RS232 communication between PC or microcontroller and GTT480272A?
_________________
Pads
Offline
 Profile
 Post subject:
PostPosted: Mon Sep 26, 2011 9:02 am
Hi Pads,
In the default configuration, the GTT will communicate at RS232 levels. If you use a micro-controller you may have to put the display in TTL mode or use a converter.
Out of the box, the unit will communicate at 115200kbps, with 8 bits data, one stop bit, no parity bit, and hardware flow control enabled.
_________________
Offline
 Profile
Search for:
Jump to:
cron
