Windows 7 and Mediaportal
andmc
Post by andmc »
Is anyone having problems using win 7 and Mediaportal? When i start mediaportal my gx screen changes to the correct colour but i see no text.
Can anyone help please?
thanks andmc :D
No issues with Mediaportal at all, I'm using it right now...
andmc
Post by andmc »
Are you using Windows 7?
I had no such problems using either Vista or Xp and Mediaportal.
thanks
andmc :)
Yes, Windows 7...
andmc
Post by andmc »
Which drivers did you use?
I have tried the win 7 rtm driver and have tried drivercore release builds 97 and 99.
It is strange that when i start mediaportal my screen changes to my mediaportal configuration colour but shows no text.
many thanks
andmc :)
I'm using pretty much all the defaults and Driver Core Build 58 from the website. Double check that MediaPortal doesn't change your contrast, that's the only thing I can think of atm.
andmc
Post by andmc »
Hello again
I tried the drivercore build 58 with the win7 usb driver.
This just stays on the Gx splashscreen
Hope you can help
thanks
andmc :)
with the splash screen never changing that means Driver Core has not started, I'll get Ray in here to give his two cents.
andmc
Post by andmc »
Hi there
Is anyone else having problems with win 7 and mediaportal, i would like to know if it is just an issue for me or a driver problem
thanks
andmc :D
Just to rule out any media portal issues, when you run lcdinfo from the GX folder does stuff appear on your display or does just keep displaying the GX logo? Does the GXDefaults tool work?
andmc
Post by andmc »
Hi Ray
If i run drivercore build 58 all i get is the gx splashscreen
If i run drivercore 97 or 99 lcdinfo works correctly as does the gx defaults tool.
Hope ypu can help
thanks
andmc :)
andmc
Post by andmc »
Any developments on my Win 7 problems?
all the best
andmc :D
Not really given LcdInfo and GXDefaults are working its kinda out of my control. The Driver stack is obviously up and working since lcdinfo is talking to it , there's no reason media portal should have issues, perhaps its some configuration issue in media portal but too be honest I'm not too knowledgable on media portal, henry? you got anything smart to add?
