GLK19264-7T-1U problems
misterdawson
Post by misterdawson »
I seem to be powering the device OK, but I'm completely unable to drive it from mogd.
It cannot automatically detect the device (unless I press a button, then it suggests rubbish).
I've set COM5 (my "prolific" USB serial adapter).
baud rate at 192000
selected the correct screen and only PCB rev.
I can't seem to make it do anything other than show the splash screen. I've tried reading some bits of data too, but it just times out, unless I press buttons, then I get more gibberish.
Anyone suggest anything, I've already tried all standard baud rates and resetting the screen.
Have you by any chance tried the display out on a different computer with a real serial comport?
Also, you might want to press on the bottom left corner key as you power the display up (manual override); this will make sure that the display will be at 19,200 baud (in case it has been changed).
misterdawson
Got it working now, I think my USB Serial adapter may have a null modem built in. :(
