Reading Multiple Keys presses over I2C using a LK204-25
Dime
Post by Dime »
It appears that when there are multiple key presses cached and I poll for a key press using I2C the LOW bit is set instead of the HIGH bit. I have tried this using the UProject software and RS232 and it works as expected there (the HIGH bit is set). However when using I2C the LOW bit is set. I have PCB revision 2.0 and firmware version 5.6.
Hello Dime,
Thanks for your post.
This was a known issue and has now been fixed in an updated firmware. Please see this PCN.
PCNs can be found here.
Dime
Firmware Updates
Post by Dime »
Can you please explain the procedure for updating the firmware in my LK204-25 device? Do I need to send the board back in or can I update it my self with a PC utility?
Hello again,
Unfortunately, we will have to get your board back here for reprogramming. I will get RMA dept to contact you for details on how to do this.
Hi Dime,
I have sent you the details required to fill your RMA in a personal message, just follow them and we'll have your LK204-25 firmware up to date.
