Typhoon Dimensions
norrin302
Typhoon Dimensions
Post by norrin302 »
Would someone be able to give me the dimensions on the Typhoon? I want to order one, but I need to make sure it will fit in my application. Thanks.
Russ
This will have to wait until monday, and then I will get you some dimensions.
norrin302
Post by norrin302 »
No problem, I'll check back tomorrow. Thanks.
Russ
Henry wrote:This will have to wait until monday, and then I will get you some dimensions.
norrin302
Post by norrin302 »
Any update on those dimensions? I'm waiting to make sure it will fit with my application before I place my order. Thanks.
Russ
right, sorry... We do not have a full Autocad drawing of this display yet, but if you are looking for display area and PCB dimensions, take a look at the GLK24064-1U manual
http://www.matrixorbital.ca/manuals/GLK ... 064-16-1U/
Hope this help.
norrin302
Post by norrin302 »
Are the dimensions the same for the GLK24064 and the Typhoon?
Henry wrote:right, sorry... We do not have a full Autocad drawing of this display yet, but if you are looking for display area and PCB dimensions, take a look at the GLK24064-1U manual
Hope this help.
Clare
Post by Clare »
Hey. I will jump in for Henry. :)
The viewing area and PCB dimensions are the same, however the PCB is layed out with different parts that are "taller" than the parts on the GLK24064-16-1U.
But the VA and AA are the exact same size between the two.
As always, we recommend that you use the display itself to work with rather than just the drawing alone. That way, there are no mistakes. :wink:
Let me know if you have any other questions.
Clare
norrin302
Post by norrin302 »
Excellent, thanks very much for that info. My only other question is, do you have an updated timeline on when the typhoon will be available?
Clare wrote:Hey. I will jump in for Henry. :)
Clare
Clare
Post by Clare »
I sure do!
We are expecting the pre-ordered GX Typhoon's to ship around the end of June, therefore, I expect general release to be sometime shortly after then.
Clare
norrin302
Post by norrin302 »
That's great. I'll be placing my order shortly. Thanks for your help.
Russ
Clare wrote:I sure do!
Clare
