i2c with PICs MSSP and Hi-Tech PIC C
jheiv
Post by jheiv » Fri Sep 08, 2006 2:25 pm
#include <htc.h>
void delay(int);
void init(void);
void i2c_init(void);
void i2c_start(void);
void i2c_write(char);
void i2c_stop(void);
void i2c_wait(void);
void main(void)
	delay(600);
	init();
	i2c_init();
	SSPIF =		0;			//CLEAR INTERRUPT
	i2c_start();
	i2c_write(0x50);		//Load LCD Address
	i2c_write(0xFE);		//Load Command
	i2c_write(0x58);		//Load Clear
	RA0 =		1;
	i2c_stop();
	while (1){
		i2c_start();
		i2c_write(0x50);
		//while(ACKSTAT == 1);
		i2c_write(0xFE);
		i2c_write(0x58);
		//while(ACKSTAT == 0);
		i2c_stop();
void init(void){
	PORTA = 	0x00;
	PORTB = 	0x00;
	ADCON1 =	0x06;
	TRISA = 	0x00;
	TRISB = 	0x00;
	TRISC = 	0x00;
void i2c_init(void){
	/* SSPCON1 REGISTERS */
	SSPEN		= 1;	//Enables Serial Port Mode
	SSPM3		= 1;	/////////
	SSPM2		= 0;	//I2C Master Mode
	SSPM1		= 0;	//
	SSPM0		= 0;	////////
	/* SSPCON2 REGISTERS */
	SSPCON2     = 0x00;
	/* SSPSTAT REGISTERS */
	STAT_SMP 	= 1;	//Slew Rate Control Disabled
	STAT_CKE	= 0;	//SMBus Specific Inputs Disabled
	SSPADD		= 0x19;
void i2c_start(void){
	SEN = 1;			//Generate Start Condition
	i2c_wait();
void i2c_write(char byte){
	SSPBUF = byte;
	i2c_wait();
void i2c_stop(void){
	PEN = 1;				//Generate Stop Condition
	i2c_wait();
void i2c_wait(void) {
	while ( SSPIF==0 );
	SSPIF = 0;
void delay(int pause){
	unsigned int i, j, k;
	unsigned int clock = 8;
	unsigned int cycle = 14;
	for(i = 0; i <= pause; i++){
	for(j = 0; j <= clock; j++){
	for(k = 0; k <= cycle; k++){
		asm("nop");
I try this code, see great looking waveforms on the scope, running full 0 - 5 V but it looks as if the two devices (LCD and uC) are conflicting. The ack bit (9th) of the data bytes sent (0x50, 0xFE, 0x47) is only around 2.5 volts. With the LCD unplugged the ack bit reads 5V (since there is nothing there to pull it low signalling an ACK) I've tried 220 ohm, 1K, 10K, even 100K ohm line pull ups. Why would the data line on the 9th bit look like its inbetween a voltage divider... Any Ideas?
Also, on the 3rd byte, the first bit of the clock looks the same way (as if one device was pulling it low while the other holding it high) with a voltage around 2.2 - 2.5V. Any help would be great!
I'm using a PIC16F876A with onboard MSSP, and LCD-2041 and the Hi-Tech C ANSI compliant compiler.
-Jim
Post by Raquel » Fri Sep 08, 2006 3:12 pm
Hello Jim,
I see that you assign SSPADD = 0x19;
Can you try this with SSPADD = 0x50:
jheiv
Post by jheiv » Mon Sep 11, 2006 7:02 am
It looks like all that did was change the clock frequency to around 25kHz and clear up the 'half-level' that was present on the clock line. But not it looks like it connects a few bytes on the clock line, so instead of being 9 distinct cycles, its something like 27 then an extended high on the clock line, then 27 cycles, etc. The data line still has some half-levels and it looks like it lost it's accuracy. Instead of clocking out a recognizable byte pattern it clocks out what looks to be:
01010000H (0x50)
11111110H (0xFE)
101100010 (0x58)
.. all continuously.
The H's correspond to the half levels on the data line.
Any ideas?
jheiv
Post by jheiv » Mon Sep 11, 2006 7:31 am
Even when I insert a pause between send commands -- like this:
		i2c_start();
		delay(1);
		i2c_write(0x50);
		delay(1);
		i2c_write(0xFE);
		delay(1);
		i2c_write(0x58);
		delay(1);
		i2c_stop();
		delay(1);
The scope still shows the half levels, with a spacing with both lines low of about 6-8x the single-byte duration
jheiv
Post by jheiv » Mon Sep 11, 2006 9:05 am
I just swapped out the LCD display with another LCD-2041 -- no luck.
Post by Raquel » Mon Sep 11, 2006 9:51 am
Hi Jim,
Can you please tell me what PCB rev LCD2041 you are connecting to? If you have a PCB 2.0, 0x50 is the default I2C address; but then if you have an older version, the I2C address depends on the setting of the RS232/I2C addr jumpers. It'll be best if you can post a picture.
Thank you.
jheiv
Post by jheiv » Mon Sep 11, 2006 10:01 am
Both LCD2041 LCDs I'm using are PCB Rev 2.0.
If I don't specify the address, it's not specified anywhere else in the program...
I tried this program just now... still nothing.
#include <htc.h>
void delay(int);
void init(void);
void main(void)
	unsigned int inc = 0;
	delay(600);
	init();
	i2c_init();
	RA0 =		1;
	i2c_start();
	i2c_write(0x50);
	i2c_write(0xFE);
	i2c_write(0x58);
	i2c_stop();
	while (1){
		inc++;
		i2c_start();
		//delay(1);
		i2c_write(0x50);
		//delay(1);
		i2c_write(inc);
		//delay(1);
		i2c_stop();
		delay(1);
void init(void){
	PORTA = 	0x00;
	PORTB = 	0x00;
	ADCON1 =	0x06;
	TRISA = 	0x00;
	TRISB = 	0x00;
	TRISC = 	0x00;
	SSPM1		= 0;	//
	SSPM0		= 0;	////////
	SSPCON2     = 0x00;
	STAT_CKE	= 1;	//SMBus Specific Inputs Disabled
	//SSPADD			= 0x19;		//~75kHz
	//SSPADD			= 0x13;		//~100kHz
	//SSPADD			= 0x07;		//~400kHz
	SSPADD			= 0x50;
	i2c_wait();
	SSPBUF = byte;
	i2c_wait();
	i2c_wait();
	while ( SSPIF==0 );
	SSPIF = 0;
		asm("nop");
Any idea why the acknowledge bit would only be pulled down to half height?
Post by Raquel » Mon Sep 11, 2006 10:31 am
Hi Jim,
I checked the datasheet for the PIC16F876A, you will need to set RA3 and RA4 to inputs. That is one reason that I can think of why the LCD can not pull the SDA line low to acknowledge.
jheiv
Post by jheiv » Mon Sep 11, 2006 12:27 pm
I did as you said... and added the following lines to my code after my initial TRISC = 0x00...
	TRISC3 = 1;
	TRISC4 = 1;
It works great! Thanks again for your time. If anyone is needs code that uses the hardware MSSP peripheral on a PIC this code works now!
Thanks again.
-Jim
Post by Raquel » Mon Sep 11, 2006 12:34 pm
Hi Jim,
I am glad that things are working now.
tedlarson
Post by tedlarson » Wed Aug 06, 2008 7:28 pm
jheiv wrote:It works great! Thanks again for your time. If anyone is needs code that uses the hardware MSSP peripheral on a PIC this code works now!
Thanks again.
-Jim
Were you ever able to get the i2c_read to work? Or only writing to the display.
-Ted
Post by Clark » Mon Aug 11, 2008 4:50 pm
Hi Ted,
Not sure if you'll get an answer from Jim or not, but I'll be more than happy to help you work out the read issue on your original post.
JeffMac
Re:
Post by JeffMac » Sun Oct 15, 2017 2:19 am
Thanks again.
-Jim
-Ted
Hey Ted did you get it working?
Re: i2c with PICs MSSP and Hi-Tech PIC C
Post by Clark » Mon Oct 16, 2017 8:05 am
Hi Jeff,
I understand you are also working with I2C, and have some questions regarding reading. I don't see a read function in Jim's code, and this is an older post so we may not get a direct response. However, if you can post your own read function we can certainly look into any issues you may be having.
Users browsing this forum: Baidu [Spider] and 17 guests
