Moderators: Henry , Mods
Posts: 3003 Joined: Tue Aug 14, 2001 6:00 pm
Post
by Henry » Thu Jun 20, 2002 9:09 am
On 2002-06-20 01:55, Sjaak wrote:
I forgot to mention that I included a waveform oscilliscope in the last version.
It's a beta version, because it's sort of slow and doesn't look so good at the moment. I could probably improve it if I make it a left and right oscilliscope and make it a bit smaller.
I didn't even notice that, cool
Pheonix
Posts: 140 Joined: Tue Nov 27, 2001 4:00 pm
Post
by Pheonix » Thu Jun 20, 2002 3:58 pm
Where is it? I cant seem to find it...
Asphix
Posts: 19 Joined: Wed Jun 19, 2002 6:00 pm
Post
by Asphix » Thu Jun 20, 2002 8:10 pm
pheonix.. where did you get that brushed metal mount for your LCD?
Sjaak
Posts: 26 Joined: Sun Jun 16, 2002 6:00 pm
Post
by Sjaak » Fri Jun 21, 2002 2:35 am
Go to the visualizations options. Select the Gfx LCD plugin, then at the bottom select either the LCD Spectrum Analyzer or the LCD Waveform Analyzer.
Post
by Henry » Fri Jun 21, 2002 10:38 am
There seems to be a problem, with spacing.. it wasn't an interger between 2 and 24... and no matter what you put in it doesn't work.
Sjaak
Post
by Sjaak » Fri Jun 21, 2002 2:26 pm
I changed the thickness from 1-16 to 2-24, to avoid some problems when using flow control.
Spacing and thickness are working on my 12232 screen, are you using a 24064 screen?
Post
by Henry » Fri Jun 21, 2002 2:44 pm
no matter what I do it does that...
Sjaak
Post
by Sjaak » Fri Jun 21, 2002 2:53 pm
Yeah, I see what the problem is. You have the thickness set to 1. Change the thickness to 2 or higher. Then it should work without any problems.
The warning message you get doesn't have anything to do with the spacing, but with the thickness.
Pheonix
Post
by Pheonix » Fri Jun 21, 2002 3:10 pm
BRILLIANT!
Just what I always wanted
Falloff r0x0rs!
Its a very good little plugin
most definately o//||s completely now.
All will be revealed about my LCD Shortly.
Post
by Henry » Fri Jun 21, 2002 3:25 pm
OK, got it working.. works GREAT on a GLK12232-25-WBL.. GREAT...
Pheonix
Post
by Pheonix » Fri Jun 21, 2002 3:35 pm
You mean I told you what to do
LOL
anyway, why can't we select 1 as a thickness?
<font size=-1>[ This Message was edited by: Pheonix on 2002-06-21 15:36 ]</font>
Sjaak
Post
by Sjaak » Sat Jun 22, 2002 3:39 am
It limited to a minimal thickness of 2 because of some shortcuts I took in speeding the display up. I'm reworking a lot of the code at the moment, to get even faster updates and better support for bigger screens (and I will change the thickness back to 1).
Post
by Henry » Mon Jun 24, 2002 6:23 pm
I just showed it to the owner/head engineer and he loved it...
He says to keep up the great work...
Asphix
Post
by Asphix » Mon Jun 24, 2002 8:49 pm
hey, i just got my lcd today and ive been messin around with it all day.. now please excuse my noobism.. but how do you install this plugin? I downloaded the .dll.. but where do i copy it to and through what does it instalize? LCDC? Im confused!
