It is currently Wed Jun 19, 2013 3:18 pm
 Page 1 of 1 [ 5 posts ]
Author Message
 Post subject: Java Developers Guide...
PostPosted: Fri Dec 13, 2002 6:37 pm
-=coming soon=-
_________________
Offline
 Profile
 Post subject: LCD Tester Installer
PostPosted: Wed Sep 10, 2003 3:54 pm
Please visit the link below for full documentation on how to install LCD Tester.
http://www.lcdforums.com/forums/viewtopic.php?t=1535
_________________
Johnny Patino
Software Developer
Offline
 Profile
 Post subject: Display Communication Sample
PostPosted: Fri Oct 10, 2003 3:32 pm
Display Communication Sample is a Java application that comes with everything including code and documentation. This simple application allows you to connect to any serial port including USB ports, and send and receive data to and from our displays. You may also send commands to the displays byte by byte. Anyway check it out for yourself, it's an easy way to get started writting your own applications to communicate to our displays using Java.
Here is the link to download Display Communication Sample:
http://www.lcdforums.com/download/CodeSamples/DisplayCommunicationSample.zip
This zip file includes...
    DisplayCommunicationSample.jar -> Double-click this file to start running the application
    DisplayCommunicationSample Documentation.html.lnk -> Shortcut to documentation home file
    javadoc -> Folder containing documentation
    src -> Folder containing source code
Note: This application uses Java(TM) Communications API 2.0, which is only available for Windows and Solaris. If anyone wants a Linux version let me know.
Requirements
For the communications API all you need to do is copy these three files from the downloaded zip file:
    win32com.dll to the .../jre/bin/ directory
    javax.comm.properties to the .../jre/lib directory
    comm.jar to the .../jre/lib/ext directory
That's it, no need to change CLASSPATH or anything like that.
C Sample
Thought I'd keep it simple and do a C sample first.
http://www.lcdforums.com/forums/viewtopic.php?t=1588
Next...
Display Communications Sample in VC++.....
_________________
Johnny Patino
Software Developer
Offline
 Profile
 Post subject:
PostPosted: Thu Jul 14, 2005 3:47 am
The link to the java example doesn't seem to be working - has it moved?
Stefan
Offline
 Profile
 Post subject:
PostPosted: Thu Jul 14, 2005 9:24 am
Hi Stefan,
A sample can be found at http://www.lcdforums.com/forums/viewtopic.php?t=2724 .
Offline
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
